Rear Axle Plates welding?
Nero
SELF INTRODUCTION: I'm an informatic engineer who just happened to leave his (relatively well paid) job to follow his passion and going to work at minimum wage as a CAD designer and a welder in a CNC laser cutting & general sheet metal fabrication shop.
In the meanwhile, I try to build a killer bike with whatever I have at hand...
Post by Nero »
Hi guys,
while I was chamfering the rear axle plates, an unexpected question rose up in my mind...
Do I have to weld them from the inside also (so that I have to chamfer both sides of the plates), or it's enough to weld them from the outside only?
Keep in mind that my plates won't be in the middle of the milled tubes, like in Gary's plans, but flush with the inside of the tubes, with the tubes simply resting on top & bottom of the plate..
Oh, and btw, these are the plates almost ready to be welded.. ;P
What I'm currently working at (and some free Italian's lessons also :D ) : http://costafabbricustomchoppers.blogspot.com/
Re: Rear Axle Plates welding?
Is there a reason you wouldn't weld both sides?...nice plates btw
rakeNtrail
SELF INTRODUCTION: Just a grumpy old welder/chopperhedd Spent far too much time burning wire for a living but hey, one does have to pay the bills ya know! Worked shipyards and fab shops welding about everything stick, mig, tig and sub-arc. Both hand held and automated. Worked weekends in a Honda shop in the late 70's and in an all bike shop in the late 80's thru early 90's. Likes? Choppers, rock-N-roll, NRA and boobies! Dislikes? PC, VD, AARP & NAACP I'm pro business and totally against big government interfering in our daily lives. Live free or die baby and you'll have to pry it from my cold dead hands. Do love little children and puppies though. Both of them can turn me into a 300lb. old softie!
Post by rakeNtrail »
Personally I would weld them both sides. Just take your time and don't overheat them or the tubing.
nice lookin plates there
Nero
Post by Nero »
Jeff L wrote:Is there a reason you wouldn't weld both sides?...nice plates btw
Well, I thought that considering my axle plates configuration, maybe the weld beads could interfere with the wheel spacers or something.. :roll:
Yes, I tend to overthink stuff... :whistle:
Many thanks to everybody!
Nero wrote: maybe the weld beads could interfere with the wheel spacers or something..
It may not be a problem unless you slide the wheel/axle as far back as it will go.
Do a mockup with the axle plates tacked in. If it's OK, weld it up.
Nero
Post by Nero »
Yes, I'll do that for sure. ;)
What Hans said....I did notice the slot looked like it might be a little tight
Nero
Post by Nero »
It is a little tight but.. however
I do not plan to move the axle to the far end of the plate anyhow, so.. ;)
monkeywrench202
SELF INTRODUCTION: I was a memeber on the old site, but couldnt log in here. I have a small shop where I do resto/ mods, build complete bikes (6 to date) ground ups. Been working @ Drive train specialists since 02 building custom automotive axles.
Post by monkeywrench202 »
"TIG" them and the welds should clear just fine.
