Found this link in a DIY section, making pushrods to your custom length...
http://aircooledtech.com/custom_push_rods/
Then went to the supplier and found this,
http://www.cbperformance.com/catalog.as ... tID=1243is link...
Chromoly with dimensions. I didn't compare to HD rods. but if you don't like adjustable rods, you might give these consideration.
8 to a set for $155, enough for 2 HD evo motors. Some high performance motors are very hard on adjustable pushrods.
I know I've bent some in the past.
custom length pushrods
Re: custom length pushrods
Thanks R'Bob.
This......I can use immediately.
http://aircooledtech.com/tools-on-the-c ... ing_beads/
andy....
You might do research on this. It sounds good, but I've seen posts on the motocy forum on craigslisthansgoudzwaard wrote:Thanks R'Bob.
that were not favorable.
The concept sounds reasonable tho.
RRB is easier.....
