Page 5 of 6
Re: Slow Build
Posted: Sat Apr 25, 2015 9:03 pm
Re: Slow Build
Posted: Sat Apr 25, 2015 9:22 pm
cool resource, thanks
Re: Slow Build
Posted: Sun Apr 26, 2015 8:18 am
by Maxthegardener
hansgoudzwaard wrote:You know the phrase " holy monkeyboots? Hi Max good to see you.
Apparently??.........nice motor hanz.....
Re: Slow Build
Posted: Tue Apr 28, 2015 12:01 pm
Thanks. I should have the charging system waiting for me when I get home. Going to look at some recycle parts today.
Going to clean it up some more and paint it flat black again.
Re: Slow Build
Posted: Wed Apr 29, 2015 12:25 am
which system did you choose?
was it spendy?
COMPU-FIRE
Posted: Thu Apr 30, 2015 3:22 pm
- ITSONLYMONEY
- COMPURECSMALL.JPG (52.12 KiB) Viewed 11129 times
There are other cheaper setups; I took the compu-fire. It was recommended by Dave on CW.
In Canadian $ it came to about $280.00 inc. delivery.
Re: Slow Build
Posted: Thu Apr 30, 2015 3:32 pm
sounds reasonable for quality.
been a long time since I researched this, but I remember Compufire having good reviews.
Re: Charging Unloads
Posted: Thu Apr 30, 2015 10:34 pm
Apparently the OE shorts to ground when the battery is fully charged.
The way compu-fire works sounds like a better system.
- thatsOK
- UNLOADS_STATOR.JPG (52 KiB) Viewed 11123 times
Re: Slow Build
Posted: Thu Apr 30, 2015 11:38 pm
sorry, you said charging system, but for some reason I was thinking electronic firing.
Didn't realize companies were making charging systems.
I had problems with the OE stator magnets myself, on a trip from Cal to New Mexico.
Had a hard tail wind, started feeling some very slight difference in something, wasn't sure what was going on.
After awhile, it kept happening more frequently, so I exited at Palm Springs and found the dealer.
That was about 1994, bike was relatively new (1991), and they worked for hours before diagnosing it as a battery.
I took off, got a mile, same thing.
Went right back. They wound up working on it for at least an hour or two past quitting time, but got it right finally.
The magnets had just started to come off, only a couple so far, and the trouble was intermittent. That's why it was hard to troubleshoot.
I wound up getting another new stator years later for different reasons.
Re: Slow Build
Posted: Fri May 01, 2015 11:51 am
railroad bob wrote:sorry, you said charging system, but for some reason I was thinking electronic firing................ They wound up working on it for at least an hour or two past quitting time, but got it right finally..........
The magnets had just started to come off, only a couple so far, and the trouble was intermittent. That's why it was hard to troubleshoot......I wound up getting another new stator years later for different reasons.
I thought so when you mentioned Crane HI-4. I don't know what is in this evo but I don't think it is Crane HI-4.
There are some great super-adhesives to hold the rotor magnets on. Unless they had a replacement rotor , this could be how they repaired your '91.
Re: Slow Build
Posted: Mon May 04, 2015 1:06 am
it was a replacement.
Mounts
Posted: Fri May 15, 2015 10:32 pm
- HELP!!!
- Mounts1.JPG (55.31 KiB) Viewed 11080 times
When the mounts were welded in by welder buddy, using the borrowed cases, the top edges are not exactly parallel. I just checked. I want to tack in the trany mounts. If I level the front motor mount, the rear motor mount is slightly off.
So , the question is, do I use the Front Motor Mount as the reference for the trany mount install, or the Rear Motor Mount, or does it matter?
I don't want any problems with the motor plate install and it's holes lining up.
Re: Slow Build
Posted: Sat May 16, 2015 6:27 pm
i have seen factory frames shimed . I would make the front level , shim the rear then set the trans . I think its a fairly common problem welding pulls things sometimes
Re: Slow Build
Posted: Sat May 16, 2015 11:23 pm
curt wrote:i have seen factory frames shimed . I would make the front level , shim the rear then set the trans . I think its a fairly common problem welding pulls things sometimes
Thanks Curt, I will do it that way.
Re: Slow Build
Posted: Sun May 17, 2015 12:16 pm
Curt's shim solution sounds like the way to go.
Looking at the front mount, are you planning a gusset plate between the vertical and horizontal plates shown?
