ok, i know this is a bit away from our standard focus, but i've got a guy asking me about a vibration he's getting in his Dyna at around 90 mph (150 km or so). he's asking me what folks in the States (and elsewhere) do to solve this problem, as it seems to be a pretty common problem in Dynas.
any ideas?
Dyna high speed vibrations?
Re: Dyna high speed vibrations?
tire pressure, tighten neck bearings, tighten handlebar lugs.
mine is a 2007 bought it new 12000 miles had the same problem was a bad front motormount appearantly the torque from burnouts tears the rubber in the mount good luck hope you figure it out
- hdwgfx
- SELF INTRODUCTION: Long time member in Greater New Orleans Area. I have been riding since I was 14 yrs old, first Harley in 1973. I own a 02 fxdx and a 01 fxdwg which is all apart. I have been a full time caregiver for my mother for the last 6 yrs. before that I was a network administrator for a big oil company but most of my life I have been mechanic/machinist etc. this is boring gezzzz
Read this ->
http://www.v-twinforum.com/forums/harle ... rials.html
I have a 02 dyna with modified 95" motor I did the above and it helps. I ride hard, this was the first rubber mount I ever rode and I hated it. I have turned some friends on to the above fix with later models ( 06 and up ) they all came back with positive results.
I also have a true track system --> http://www.true-track.com/ which definitely works ... diff is like day and night
NOTW
damnow you got me thinking i let the dealer install the mount now im going to have to check it tomorrow . ive been thinkin about the true track hopeing i can afford it this winter it always feels like the rear tire is flat with theese rubermount frames im hopeing it helps
- hdwgfx
Curt from what I have read the rubber mount system was designed to have 3 links , top front and rear by Eric Buell the factory didn't think the front and rear were necessary LOL - the true track is worth the money IMO ( several of my friends bought them also ) and will get rid of that back wheel feeling like it's moving around. I also removed my rubber mounts and filled the gaps between the rubber and the metal with silicone, I did this before I bought the true track, this made a big difference, the silicone eventually worked it's way out after @ 8k hard miles, I'm gonna pull them out soon and fill the gaps with JB Weld or something else............ sonner or later they will be solid LOLOLOL
NOTW
thanks for your input, guys. that's the reason i love this place.
it def needed to be shimed almost a quarter of an inch should have known better than let the dealer screw with it they never get it right thanks for the tip there havent test rode it yet dam weather been crap
