Page 5 of 11
Re: Front engined VW
Posted: Sat Sep 30, 2017 11:43 pm
by budoka
hey, if it's going in a bike/trike it's all good, isn't it? heck, we have car/truck/gun stuff here too. it's all fabrication and building! post whatever you feel like, we all love learning something new.
Posted: Sun Oct 01, 2017 8:09 pm
by DeathBySnuSnu
VW engine stuff.
Modified my little engine further. It had been a 2110 with mofoco 050 heads and a 260 at .050 cam. All the "normal" hot rod stuff.
It had gotten old and tired (had been around since the early 80's) and I always wanted to fuel inject it.
Not real sure why I made it bigger. I suppose cuz I am to much of an old motorheads.
Bumped up from an 82mm stroke to 86mm.
And increased bore from 90.5 to 94mm.
![20150205_185625_zpswxger31e.jpg](./download/file.php?id=2537&sid=ac2671d71daa5e26feeb9699e33fa19e)
- 20150205_185625_zpswxger31e.jpg (102.91 KiB) Viewed 6890 times
![20150205_185918_zpsl9mmdgy9.jpg](./download/file.php?id=2538&sid=ac2671d71daa5e26feeb9699e33fa19e)
- 20150205_185918_zpsl9mmdgy9.jpg (177.1 KiB) Viewed 6890 times
![20150201_163409_zps20exvsqd.jpg](./download/file.php?id=2539&sid=ac2671d71daa5e26feeb9699e33fa19e)
- 20150201_163409_zps20exvsqd.jpg (162.58 KiB) Viewed 6890 times
![20150115_171023_zpsd1qwvdxa.jpg](./download/file.php?id=2540&sid=ac2671d71daa5e26feeb9699e33fa19e)
- 20150115_171023_zpsd1qwvdxa.jpg (118.53 KiB) Viewed 6890 times
Posted: Sun Oct 01, 2017 8:44 pm
by DeathBySnuSnu
Moved the oiling around via the Hoover airplane mods.
All the way. Oil passages. Notched lifters and grooves in rockers.
Plus I added squirters to the rockers.
![15069045510941.jpg](./download/file.php?id=2543&sid=ac2671d71daa5e26feeb9699e33fa19e)
- 15069045510941.jpg (103.76 KiB) Viewed 6890 times
![15069045410410.jpg](./download/file.php?id=2544&sid=ac2671d71daa5e26feeb9699e33fa19e)
- 15069045410410.jpg (72.76 KiB) Viewed 6890 times
![15069050050262.jpg](./download/file.php?id=2545&sid=ac2671d71daa5e26feeb9699e33fa19e)
- 15069050050262.jpg (45.81 KiB) Viewed 6890 times
![15069050387183.jpg](./download/file.php?id=2546&sid=ac2671d71daa5e26feeb9699e33fa19e)
- 15069050387183.jpg (82.2 KiB) Viewed 6890 times
Posted: Sun Oct 01, 2017 10:09 pm
by DeathBySnuSnu
86mm crank
![20141116_072836_zpsqiuv6xfx.jpg](./download/file.php?id=2547&sid=ac2671d71daa5e26feeb9699e33fa19e)
- 20141116_072836_zpsqiuv6xfx.jpg (58.68 KiB) Viewed 6886 times
5.5 long Chevy rods
![20141116_073546_zpsdop7l9hn.jpg](./download/file.php?id=2548&sid=ac2671d71daa5e26feeb9699e33fa19e)
- 20141116_073546_zpsdop7l9hn.jpg (41.56 KiB) Viewed 6886 times
94mm forged mahles
![20150109_132018_zpso9tyldhr.jpg](./download/file.php?id=2549&sid=ac2671d71daa5e26feeb9699e33fa19e)
- 20150109_132018_zpso9tyldhr.jpg (55.59 KiB) Viewed 6886 times
Engle fk10 cam
![20150119_160611_zpsfe3e1tih.jpg](./download/file.php?id=2550&sid=ac2671d71daa5e26feeb9699e33fa19e)
- 20150119_160611_zpsfe3e1tih.jpg (105.73 KiB) Viewed 6886 times
Posted: Sun Oct 01, 2017 10:34 pm
by DeathBySnuSnu
O ringed the pump into the case.
![15069112705184.jpg](./download/file.php?id=2551&sid=ac2671d71daa5e26feeb9699e33fa19e)
- 15069112705184.jpg (49.15 KiB) Viewed 6886 times
Made a pump cover with the filter where I need it to be and so on....
![15069112977225.jpg](./download/file.php?id=2552&sid=ac2671d71daa5e26feeb9699e33fa19e)
- 15069112977225.jpg (64.37 KiB) Viewed 6886 times
Posted: Mon Oct 02, 2017 6:38 am
by budoka
good grief, that is incredible! where did you pick up the knowledge about doing those mods? probably just years and years of playing around with VW engines i'd bet. regardless, that's some amazing stuff.
Posted: Mon Oct 02, 2017 8:03 am
by DeathBySnuSnu
Lots of one off parts.
![15069451246710.jpg](./download/file.php?id=2553&sid=ac2671d71daa5e26feeb9699e33fa19e)
- 15069451246710.jpg (106.18 KiB) Viewed 6881 times
Oil sump baffle. Normal windage tray would not fit. Had to make somthing else.
![15069450159656.jpg](./download/file.php?id=2554&sid=ac2671d71daa5e26feeb9699e33fa19e)
- 15069450159656.jpg (61.86 KiB) Viewed 6881 times
No distributor drive. Baffle over hole. Distributor hole is now the oil fill.
![15069450373707.jpg](./download/file.php?id=2555&sid=ac2671d71daa5e26feeb9699e33fa19e)
- 15069450373707.jpg (81.59 KiB) Viewed 6881 times
Whittled a Chevy alternator mount.
![15069451018859.jpg](./download/file.php?id=2556&sid=ac2671d71daa5e26feeb9699e33fa19e)
- 15069451018859.jpg (83.9 KiB) Viewed 6881 times
Oil cooler block off and ford coil mount.
![15069451445011.jpg](./download/file.php?id=2557&sid=ac2671d71daa5e26feeb9699e33fa19e)
- 15069451445011.jpg (54.04 KiB) Viewed 6881 times
Posted: Mon Oct 02, 2017 8:15 am
by DeathBySnuSnu
No oil pistons or oil controll in the case.
All plugged off.
Bore plug.
![15069460832233.jpg](./download/file.php?id=2558&sid=ac2671d71daa5e26feeb9699e33fa19e)
- 15069460832233.jpg (75.05 KiB) Viewed 6881 times
External dry sump style oil pressure regulator.
![15069460658952.jpg](./download/file.php?id=2559&sid=ac2671d71daa5e26feeb9699e33fa19e)
- 15069460658952.jpg (52.88 KiB) Viewed 6881 times
Mock up and dial in.
![15069450833588.jpg](./download/file.php?id=2560&sid=ac2671d71daa5e26feeb9699e33fa19e)
- 15069450833588.jpg (83.54 KiB) Viewed 6881 times
![15069461647854.jpg](./download/file.php?id=2561&sid=ac2671d71daa5e26feeb9699e33fa19e)
- 15069461647854.jpg (92.29 KiB) Viewed 6881 times
Case painted with silver por15.
![15069462100865.jpg](./download/file.php?id=2562&sid=ac2671d71daa5e26feeb9699e33fa19e)
- 15069462100865.jpg (77.81 KiB) Viewed 6881 times
Posted: Mon Oct 02, 2017 8:20 am
by DeathBySnuSnu
Posted: Mon Oct 02, 2017 8:27 am
by DeathBySnuSnu
With no gen stand I had to make a Vent box.
![15069471941780.jpg](./download/file.php?id=2567&sid=ac2671d71daa5e26feeb9699e33fa19e)
- 15069471941780.jpg (96.79 KiB) Viewed 6881 times
Posted: Mon Oct 02, 2017 6:27 pm
by DeathBySnuSnu
The whole rotating mess went out to the balance shop.
Got a tight tolerance 7500 balance job.
![20160719_121218_zpscmlqtita.jpg](./download/file.php?id=2568&sid=ac2671d71daa5e26feeb9699e33fa19e)
- 20160719_121218_zpscmlqtita.jpg (115.75 KiB) Viewed 6870 times
Added an inner oil groove to the main bearings for more flow to rod journals.
![20160904_143409_zpsxycyuxyr.jpg](./download/file.php?id=2569&sid=ac2671d71daa5e26feeb9699e33fa19e)
- 20160904_143409_zpsxycyuxyr.jpg (141.23 KiB) Viewed 6870 times
The bottom end going together.
This one takes the metal backed #2 split main bearing on #3 also.
![20160917_193146_zpsp607mzxa.jpg](./download/file.php?id=2570&sid=ac2671d71daa5e26feeb9699e33fa19e)
- 20160917_193146_zpsp607mzxa.jpg (141 KiB) Viewed 6870 times
Posted: Mon Oct 02, 2017 6:31 pm
by DeathBySnuSnu
End play set.
Lightened forged flywheel and large higher torque nut.
![20160923_163644_zpsdvjgyhre.jpg](./download/file.php?id=2571&sid=ac2671d71daa5e26feeb9699e33fa19e)
- 20160923_163644_zpsdvjgyhre.jpg (127.29 KiB) Viewed 6870 times
Heat insulation ceramic coated the piston heads.
![20161015_101428_zpsjipy5ku0.jpg](./download/file.php?id=2572&sid=ac2671d71daa5e26feeb9699e33fa19e)
- 20161015_101428_zpsjipy5ku0.jpg (83.82 KiB) Viewed 6870 times
Posted: Mon Oct 02, 2017 6:38 pm
by DeathBySnuSnu
With the longer rod and the 86 stroke and B pin pistons I am going with a zero deck height with copper rings for the deck.
That left me spacers under the cyl bases.
![20150107_175552_zpsaqxmilly.jpg](./download/file.php?id=2573&sid=ac2671d71daa5e26feeb9699e33fa19e)
- 20150107_175552_zpsaqxmilly.jpg (80.19 KiB) Viewed 6870 times
![20150115_171809_zps1phffzwq.jpg](./download/file.php?id=2574&sid=ac2671d71daa5e26feeb9699e33fa19e)
- 20150115_171809_zps1phffzwq.jpg (84.71 KiB) Viewed 6870 times
Posted: Mon Oct 02, 2017 6:57 pm
by DeathBySnuSnu
Heads were a performance model to start with.
Had to modify for the larger displacement.
![15069842517540.jpg](./download/file.php?id=2575&sid=ac2671d71daa5e26feeb9699e33fa19e)
- 15069842517540.jpg (88.19 KiB) Viewed 6870 times
Started by welding up the chambers.
![20151013_164952_zpstwme2a7p.jpg](./download/file.php?id=2576&sid=ac2671d71daa5e26feeb9699e33fa19e)
- 20151013_164952_zpstwme2a7p.jpg (240.31 KiB) Viewed 6870 times
And reshaping.
![20151030_180129_zpsduj3ug7m.jpg](./download/file.php?id=2577&sid=ac2671d71daa5e26feeb9699e33fa19e)
- 20151030_180129_zpsduj3ug7m.jpg (207.88 KiB) Viewed 6870 times
Posted: Mon Oct 02, 2017 7:04 pm
by DeathBySnuSnu
Some heavy port work.
![20160305_124745_zpszm24zrhs.jpg](./download/file.php?id=2578&sid=ac2671d71daa5e26feeb9699e33fa19e)
- 20160305_124745_zpszm24zrhs.jpg (173.82 KiB) Viewed 6870 times
Ceramic coated.
![20161029_104845_zpsonyd9obi.jpg](./download/file.php?id=2579&sid=ac2671d71daa5e26feeb9699e33fa19e)
- 20161029_104845_zpsonyd9obi.jpg (166.3 KiB) Viewed 6870 times
Buncha new parts.
