Page 2 of 2
Re: layering metal
Posted: Sat Jan 21, 2012 6:07 pm
by gww25
For those little tabs I would strongly suggest that you recut them using 3/8" (or 1/2") material to begin with as they probably won't be flat by the time you weld them together and then grind them down. This is one instance where taking a shortcut may not be a good idea even though in theory it will work.
Re: layering metal
Posted: Sat Jan 21, 2012 9:12 pm
by Maxthegardener
Could you get fancy with some flush head rivets??
Re: layering metal
Posted: Sun Jan 22, 2012 10:12 am
by buellfun
Ok I will quit being a cheap ass. I guess i will learn how to use that 4th axis on the new mill. I was trying not to use any machine.
hell we will keep the pcs around for some large tab or brackets.
and as to the rivit, i was going to heat a grade 5 bolt then flaten the back side.
Chris
Re: layering metal
Posted: Mon Jan 23, 2012 7:29 pm
by joechop
....glad to hear
I think you'll be happy you went the non-laminated route
