Page 5 of 5
Re: jonester JD2 Bender Build
Posted: Sat Apr 19, 2014 4:56 pm
by jonester123
More progress, finished drilling plates for mounting the ram. Need to do some fabrication of one plate to get it ready to weld up to the mounting bracket on ram, thick plate so need to bevel for real good solid penetration.
![biggrin :D](./images/smilies/icon_e_biggrin.gif)
Once that's all done then figure out best way to mount bender on table or vise not sure yet.
Posted: Fri Apr 25, 2014 3:58 pm
by jonester123
I purchased some square tubing 4ft long 2by2 and metal plate, making the jd2 bender solid mounting. I have some heavy duty pallets that I am considering mounting it on.
Posted: Sat Apr 26, 2014 4:10 pm
by jonester123
Hey guys and gals, used heavy duty pallet to mount my jd2 bender on. Should work good since the bender is now air hydraulic, less stress on mounts when bending.
Posted: Fri May 16, 2014 4:44 pm
by jonester123
Hey guys and gals, well been trying to mount my jd2 bender on steel pole. I noticed my ram does not function properly laying flat mounted, it only works standing straight up. So figuring out best way to mount the bender on pole so ram will work properly and be able to load tubing , never easy.
Posted: Sat May 17, 2014 6:17 pm
by jonester123
Working on mounting jd2 bender on steel pole, making sure it is all real good and solid.
Posted: Sat May 17, 2014 8:08 pm
by gww25
I've got some better plans for a new version of my bender than you might be able to use with your ram. Send me an email.
Posted: Sat May 17, 2014 8:37 pm
by jonester123
Thanks Gary, I had to change my bender mounting because my ram only works when in almost straight up mounting. It does not build up pressure mounted straight across the way I was hoping to mount. My email Is
trejones@shaw.ca
Posted: Sat May 17, 2014 9:25 pm
by gww25
Almost all of the less expensive rams and air/hydraulic benders only operate if they are on a slight incline. Take a look at
http://chopperhandbook.com/vertbender.htm as it will give you some suggestions about how best to take advantage of your new setup.
Posted: Wed May 21, 2014 9:57 pm
by jonester123
Thanks Gary. going to try my setup first. If I am not happy then I will give some of your ideas a try.
Still working on front of ram to make mount bracket to weld it in place nice and solid.
Posted: Sat May 24, 2014 8:17 pm
by jonester123
Been fabricating last ram mount bracket, need to finish final welding on it yet.
Posted: Tue May 27, 2014 9:35 pm
by jonester123
Completed the air hydraulic conversion on my jd2 model three bender build, I have only one die size 1 1/8" 4.5clr. Need to purchase 1" die and 1 1/4" die, so going to order some tube for the die I have so I can do some practice bends.
