What material do you all make axles with? I have added a section of 4140 to my McMaster-Carr order but wanted to be sure before I order. This is for a leafer front end. Thanks
Ken
Front axle material
- SELF INTRODUCTION: My name is Ken Heaton. I've been in the medical field in the Army for the past 18 years and work on and build bikes as a hobby. My main hobby and goal is to think of parts that do not exist and make them or modify existing parts. I currently own a 99 Softtail that I bolted together, a 78 Triumph bobber that i built from the ground up, a 75 CB360 cafe, and a 76 Kawasaki KH500 that needs a lot of work. I joined the original forum about 8 years ago and I'm glad to see it up and running again!
Re: Front axle material
Nothing?? I know some of you make your own. Just need to know if 4140 is good or overkill.
Ken
Ken
I've said this in many places many times , mcpherson strut cartridge actuator shafts are large enough to be turned down to suit the axle requirement front or rear for most any bike I ever heard of and are far more than "good enough"
- SELF INTRODUCTION: Just an Iowa country boy that has been pouring concrete for over 30 years. I have been around for awhile. I have watched 3 forums come and go. I built my first chop with the help of the great guys on this forum. I plan on building a few more. $$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$ I don't have the 200 word in me this morning! 8)
1045, 1050 is plenty good enough. That's what most car axles are made of.
i've used stainless with good results, but exactly what it was, is lost in the fog of time.
Thanks everyone. I have 1045, now I have to wait the use my buddys lathe because I don't want to try it on my small HF
Let us know how it goes.
You can also source a car or truck axle (rwd) from any salvage yard (car breaker in britain) and have it machined into axle shafts for your bike !
Hmmm, I thought instantly about axles in a typical car or pickup, and how that would require a LOT of machining,gearhead1951 wrote:You can also source a car or truck axle (rwd) from any salvage yard (car breaker in britain) and have it machined into axle shafts for your bike !
BUT, an axle from a vehicle with CV joints, like a Subaru?, don't they have a small diameter axle?
That seems like they might be a really good source for axle material.
