Making Cable Ends
Posted: Fri Apr 12, 2013 11:16 pm
Thought I'd share how I made Cable ends for my Brake.I'll be doing the same for the Clutch.1st) was to make a little Solder Pot
solder pot.JPG (123.17 KiB) Viewed 7857 times
...2nd) you'll need Flux for Stainless, got this at my Welding Supply
3rd)is to prep the Cable.I started by opening up the end with a small Nail.Just poke it into the Cable a bunch of times.This will allow the Flux into the Strands & give the Solder more to hold.This is unfortunatly the only Pic that I got.The 1st poke.But after it was done,I cut a small piece of the Nail & slide it through the Cable (it looked like the Pic)
.Let the Cable soak in the Flux for a couple Minutes.While it was soaking, I heated up the Pot with a Torch.Once hot start pushing Solder in.It should melt on contact.The way I did this was I dipped the Cable in the Solder just to Tin it.After it was Tinned, I took off the heat & started dipping again(it seems to get more Solder on the Cable as the Solder cools alittle).Continue till you get a nice little Glob on the end.Again forgot to take Pic.And now you can sand to the shape you need
And here it is installed
I really pulled on this & it held.Hope someone finds this usefull.
Re: Making Cable Ends
Posted: Sat Apr 13, 2013 4:13 pm
by sleepyonthree
I like that little solder pot plus the reminder you need the specific flux. What type of solder did you use?
:text-goodpost:
Posted: Sat Apr 13, 2013 8:10 pm
I used regular old Silver Solder.There are others out there with higher Silver content (higher Silver=stronger Joint) but I pulled on the Cable with the end locked in the Foot control, with both Hands & it held.
Posted: Sun Apr 14, 2013 12:32 am
by TattooLeeRoy
I used plumbing solder to build tattoo needles, they're stainless, didn't matter what kind. The flux was the important part, stay brite was the only one worth a crap.
Posted: Sun Apr 14, 2013 9:42 pm
by Maxthegardener
Neat, thankyou Jeff..
