Any quick fixes for broken ironhead inner primary?
Posted: Mon May 12, 2014 6:01 pm
by justin caise
I screwed up today by cranking down on one of the clutch cover screws too much on a 72(?) Sportster and split the aluminum primary (integral to the engine). Just a hairline, visible from the outside, right at the boss where the top screw goes in. I think this happened because there was left over dried gasket goop in the hole - which I've now learned to clean out before closing things up- and because I was rushing.
Can I fix this with, like, with toothpaste, or hairspray, or apple cider vinegar or something?
(Feeling like Gilligan.)
Re: Any quick fixes for broken ironhead inner primary?
Posted: Mon May 12, 2014 7:12 pm
by gww25
Did you hear a loud 'poping' sound when you tweaked down on the fastener? If not then you most likely just opened up a crack that was already there and the 'goop' was probably some other person 'fix'. If the crack is on the 'weak' side of the boss then just seal it with J-B weld as it probably won't propagate any further.
Posted: Mon May 12, 2014 8:08 pm
by justin caise
Thank you Gary.
Actually I heard two popping sounds. the first was the splitting aluminum, then my palm hitting my forehead.
Posted: Tue May 13, 2014 5:31 pm
XL forum deals with this. Some good advice online.
Posted: Tue May 13, 2014 11:42 pm
My dad showed me how to use JB Weld for aluminum on a transmission case for a Yamaha, years ago.
Not sure how difference there is in internal pressures, but this one held fine for thousand of miles.
Posted: Wed May 14, 2014 12:00 am
An interesting link.
www.ironheadcycle.com/
If you look under "tech Info" he has some useful tools.
