Got my frame welded. Thanx for all the help. I got my wheels f/egay. Apparently, they got rid of them because the wheel bearings were frozen into the wheels. Tried making an internal collet...striped right out. Tried heat...not good. Eventually it took brute force via alot of tonnage with a hyd bearing press. It sounded like a gun when the bearing finally broke loose. Checked the wheel and everything looks undamaged except for some galling.
I never press bearings without lube. Do you guys use lube when pressing bearings? Is anti-sieze a better idea?
Wheel bearing lube
Re: Wheel bearing lube
i always use anti sieze
Thanx, Curt. Good enough for me!
Now to cut some spacers.
- jimmib
- SELF INTRODUCTION: Hello everyone. first of all a big thanks to "Dan the Man". Some of you know me from the previous (2) boards and some don't, so here goes. I have been a fabricator/welder for over 40 years now. Damn that's a helluva long time to do anything! Anyways, I have built literaly 100's of street rods, pro streeters, racecars, bikes and trikes over the years. Never made the headlines and never will. I do what I do because it is the love of my life.
I enjoy reading the posts on the forum and try to contribute when I can. I am sure that this will be every bit as good as the CBH forum, as we will have most of the same folks. Good luck and post a lot of pics!! Jim - Location: Lowcountry USA
Anti sieze or lubriplate work well. Freeze your brgs for several hrs and heat hubs with a heat gun right before installation. All helps!
