62 Chopped FL Rebuild
- 2Loose
Re: 62 Chopped FL Rebuild
Am pretty unedumacated on tire sizing technology, does that oem HD, rear 16", spoked wheel, I have equate to a 130??
Precisely what is that, 130 mm ??
Inquiring minds want to know....
Willy
Willy
http://ridewrightwheels.com2Loose wrote:Am pretty unedumacated on tire sizing technology, does that oem HD, rear 16", spoked wheel, I have equate to a 130??
Willy
I am using the chart, at the bottom of the page.
- 2Loose
Thanks, that helps....
Ran into a problem....
![Image](http://www.wheelsmaui.com/UserFiles/Image/62FLProject3/62PanRebuild48s_july_2016.jpg)
My "police special" high output fan cooled generator does not fit into my Denver's frame, the scroll cage for the fan hits the left downtube....
![Image](http://www.wheelsmaui.com/UserFiles/Image/62FLProject3/62PanRebuild49s_july_2016.jpg)
I think this frame is sized for the smaller 6v generator that most of the street bike panheads were fitted with,
so now I am looking for one of those....
![Image](http://www.wheelsmaui.com/UserFiles/Image/62FLProject3/62PanRebuild50s_july_2016.jpg)
If I had caught this before painting the frame, I could possibly have done a modification to the frame to
accomodate this generator, but too late now....
Willy
Willy
- 2Loose
Started putting the clutch together, question here, do these rollers for the clutch basket run dry? Or are they lubricated somehow? this clutch is a dry, open primary setup....
![Image](http://www.wheelsmaui.com/UserFiles/Image/62FLProject3/62PanRebuild51s_july_2016.jpg)
I'm considering putting a small amount of fiber type wheel bearing grease on these, but am afraid of that stuff getting into the clutch plates and screwing up the works....
Any ideas?
These are the clutch parts I'm running....
The clutch "fingers" look worn, but are just discolored, can't feel any grooves in them with my fingernail...
![Image](http://www.wheelsmaui.com/files/62Panhead02sMay2014.JPG)
![Image](http://www.wheelsmaui.com/files/62Panhead03sMay2014.JPG)
Willy
Any ideas?
Willy
I would not mess with the grease.2Loose wrote:Started putting the clutch together, question here, do these rollers for the clutch basket run dry? Or are they lubricated somehow? this clutch is a dry, open primary setup....
Any ideas?
Willy
I could sure be wrong, but if it was me, I would check it out further.
- 2Loose
Did another trial fit of all the clutch parts....
![Image](http://www.wheelsmaui.com/UserFiles/Image/62FLProject3/62PanRebuild59s_july_2016.jpg)
![Image](http://www.wheelsmaui.com/UserFiles/Image/62FLProject3/62PanRebuild55s_july_2016.jpg)
Locked down the compressed spring pack, and took it apart again....
![Image](http://www.wheelsmaui.com/UserFiles/Image/62FLProject3/62PanRebuild58s_july_2016.jpg)
Then installed it with the belt, adjusted the belt to about 3/4" of flex from "neutral" to "down with thumb pressure"
![Image](http://www.wheelsmaui.com/UserFiles/Image/62FLProject3/62PanRebuild61s_july_2016.jpg)
Found this problem, the belt is just barely rubbing against the frame tube...
![Image](http://www.wheelsmaui.com/UserFiles/Image/62FLProject3/62PanRebuild63s_july_2016.jpg)
I'll have to put some spacers under the trans plate, probably 1/8" will do it...
More later...
Aloha,
Willy
Plenty more pix here...
More later...
Aloha,
Willy
I see you used the grease. I goofed.
The redo is looking real nice ; and clean too.
![Bang Head :angry-banghead:](./images/smilies/angry/banghead.gif)
- 2Loose
An early test setup, it just felt right, can't wait to really ride it...
Soon...
Willy
Just an idle thought, if you are going to shim the trans up 1/4" would that same 1/4" under the engine make the genny clear?
- 2Loose
Hmmmmmm....
Hmmmmm...
and more
Hmmmm...
Kinda sounds like an idea....
Am working on another idea, will post pix when I get something worked out...
W.
Hmmmmm...
and more
Hmmmm...
W.
- 2Loose
Pulled the shroud off the generator, no problem now!!!
Looking at modifying the shroud, no decision yet...
![Image](http://www.wheelsmaui.com/UserFiles/Image/62FLProject3/62PanRebuild73s_july_2016.jpg)
- 2Loose
Found some wheel bearing grease in my stash that looks good for the clutch hub bearings...
![Image](http://www.wheelsmaui.com/UserFiles/Image/62FLProject3/62PanRebuild66s_july_2016.jpg)
![Image](http://www.wheelsmaui.com/UserFiles/Image/62FLProject3/62PanRebuild65s_july_2016.jpg)
- 2Loose
I run solid footpegs, they act as "crash guards" if I go down.
Went down once, long time ago, and these pegs and the handlebars kept most of the bike up off the pavement, damage was minimal...
![Image](http://www.wheelsmaui.com/UserFiles/Image/62FLProject3/62PanRebuild70s_july_2016.jpg)
![Image](http://www.wheelsmaui.com/UserFiles/Image/62FLProject3/62PanRebuild71s_july_2016.jpg)
LINK to more pix (scroll down)
How complicated would it be to just make a new shroud ? I've done similar things on old equipment while in the navy ! Sheetmetal work aint that hard !!
gearhead1951 wrote:How complicated would it be to just make a new shroud ? I've done similar things on old equipment while in the navy ! Sheetmetal work aint that hard !!
That grease tin looks like just the right size.
![lol :lol:](./images/smilies/icon_lol.gif)
