Cut them.
Welded
Back bone and down tube or whatever thing is made.
![Image](http://i.imgur.com/y2M35Hgl.jpg)
![Image](http://i.imgur.com/Br6A89Tl.jpg)
![Image](http://i.imgur.com/qbiK0Q5l.jpg)
![Image](http://i.imgur.com/qslTpXJl.jpg)
![Image](http://i.imgur.com/X8jQMNRl.jpg)
![Image](http://i.imgur.com/2XZLwsxl.jpg)
![Image](http://i.imgur.com/VhkKWWil.jpg)
![Image](http://i.imgur.com/03cfQUel.jpg)
![Image](http://i.imgur.com/S95m7zXl.jpg)
![Image](http://i.imgur.com/mOmMfrEl.jpg)
![Image](http://i.imgur.com/f7ahBRyl.jpg)
![Image](http://i.imgur.com/DEXRdVRl.jpg)
![Image](http://i.imgur.com/aVBiitVl.jpg)
![Image](http://i.imgur.com/IhgTpHal.jpg)
![Image](http://i.imgur.com/i49YdGWl.jpg)
![Image](http://i.imgur.com/6UBVyUVl.jpg)
![Image](http://i.imgur.com/W4d0ikcl.jpg)
![Image](http://i.imgur.com/x2xNEEml.jpg)
![Image](http://i.imgur.com/1PU1EMil.jpg)
![Image](http://i.imgur.com/ebSyaLSl.jpg)
![Image](http://i.imgur.com/3rZNfcql.jpg)
![Image](http://i.imgur.com/q3llvtMl.jpg)
![Image](http://i.imgur.com/IFHZn5fl.jpg)
![Image](http://i.imgur.com/inZPD50l.jpg)
![Image](http://i.imgur.com/crAoVKsl.jpg)
![Image](http://i.imgur.com/vON4w1al.jpg)
![Image](http://i.imgur.com/9rgjl0jl.jpg)
![Image](http://i.imgur.com/4DnQSeil.jpg)
![Image](http://i.imgur.com/TfUAU6cl.jpg)
![Image](http://i.imgur.com/6hhQaxsl.jpg)
![Image](http://i.imgur.com/3atNdJbl.jpg)
![Image](http://i.imgur.com/zPgVO0Jl.jpg)
![Image](http://i.imgur.com/ldCJ69Il.jpg)
![Image](http://i.imgur.com/IQyBvbyl.jpg)
![Image](http://i.imgur.com/6wOuihil.jpg)
![Image](http://i.imgur.com/WtTwBEBl.jpg)
![Image](http://i.imgur.com/HN5m8Jcl.jpg)
![Image](http://i.imgur.com/UUA9rqgl.jpg)
![Image](http://i.imgur.com/FvTG4TUl.jpg)
![Image](http://i.imgur.com/WrbWErql.jpg)
![Image](http://i.imgur.com/1itJgBol.jpg)
![Image](http://i.imgur.com/PmnfaxZl.jpg)
Like the drawing "C " that I posted on "Springers , girders and leafers " here at the CCCustomize IT wrote:Just for you friend I will give advance of my design for the front end it may be crazy or just plain stupid?
I will make a set of I beam forks that bolt fixed to the trees.
The lower part will have a set of springer rockers hopefully Sugarbear style.
About half way up the legs will be a set of 2 links like on a girder fixed in between the legs.
The springer rocker tubes will connect to them with a pin/bolt set screwed in position.
In between the the 2 links will be a shock off the back of a old jap bike. The top mount eyelet of it will be fixed to lower tree.
As the rocker on wheel moves it will rotate the links up and compress the shock.
