Honda Rebel 250 Springer Build
Re: Honda Rebel 250 Springer Build
Spring perch with the Rebel badge. Where it will be on the springer.
The frame made it in the jig finally and started loosing weight. He he ha ha
Frame slugs arrived.
Lost a little more weight.
Started on the lower tubes and moved the rear axle jig back 4 inches.
Bent some more tubing up today.
Bent a little kick up at the end. Have something planed for the ending. Hope it works out.
Got the bottom tubes about where I want them to look.
No turning back now. Swing arm brackets are gone. Gotta love cardboard.
Started on the down tube this mourning. Time to roll the curve in it.
1-1/2 DOM 0.120 Tubing. I use 0.120 wall on everything. It's stronger than the factory 0.080 wall tubing.
Still have a little ways to go.
Almost there. Final tweking and cutting to fit.
Got the down tube fitted up this mourning before work.
Just a sneak peek. Will have to wait to see where this is headed.
Here it is the down tube. Turned out pretty good.
Took big pieces and made little pieces.
Cut a few holes in the down tube.
Inserted the little pieces into the big piece (down tube)
Well here it is. Still have to weld up the little pieces.
Dude...you really should putt this in build logs. The job you're doing deserves a dedicated thread.
I agree with Jeff.
I am following this one.
Lower rail radius cut. Now to mold and shape the axle plate to better fit the radius.
Playing with the cardboard again. Making a template to help fit the axle plates to tubing radius.
