Page 4 of 14
Re: Fractured Lacerations - Build - I Broke my Knife!
Posted: Wed Nov 12, 2014 3:20 am
by Customize IT
Got the 2 axle plate pieces made.
The rear tail section has all its parts.
Now to mind fight the motor mounts. May as well start with the hardest? I only left myself 3/4 in for engine removal of clearance without taking the oil pan off. Helps the look of bike but, no tabs can be welded to the top off this rail? May have to brace it out to the side and make a plate that bolts to the side and drill 2 1/2 holes for bolts each side off the hole there?
Posted: Wed Nov 12, 2014 4:54 am
by Customize IT
This is what I was thinking?
Just make a couple spacers to space it out from the rail and 3/8ths bolts should work 2 of them?
Posted: Wed Nov 12, 2014 11:16 am
by Customize IT
May just do this?
Hell I might be the only one to ever look at the motor mounts on her?
Are they real noticable out the side like this?
Posted: Wed Nov 12, 2014 11:25 am
by Customize IT
Might be able to use them there to make a exhaust mount also off of latter?
Posted: Wed Nov 12, 2014 2:34 pm
by Customize IT
Got those 2 mounts done and on to the next hardest one.
This has to be able to drop away from motor and come out the side.
Welded the cross bar in already now to make the connecting part to the back bone.
Posted: Thu Nov 13, 2014 3:03 am
by Customize IT
Got that mount done and it comes in and out with engine in the frame. Did not want to go down to the cross brace here for the oil coolers to have enough room.
On to the next one there is plenty of room here.
Posted: Thu Nov 13, 2014 4:26 am
by Customize IT
Posted: Thu Nov 13, 2014 7:21 am
by Customize IT
Got the front motor mount made.
Now to make the support beam for the downtube thing.
Posted: Thu Nov 13, 2014 11:35 am
by Customize IT
Posted: Fri Nov 14, 2014 6:04 am
by Customize IT
Posted: Fri Nov 14, 2014 2:05 pm
by Customize IT
Posted: Fri Nov 14, 2014 2:20 pm
by Customize IT
Scored a Vertical bandsaw and a bigger sandblaster.
The sand blaster the top opens like a clam shell and can fit full engines in plus has a dust removal system.
Posted: Fri Nov 14, 2014 9:58 pm
Posted: Sun Nov 16, 2014 11:56 am
by Customize IT
Posted: Sun Nov 16, 2014 12:40 pm
The blast cabinet is probably my most used tool.Wish I had a dust remover for it....good score dude...seems all you need to do now is build yourself an oven & start powder coating...frame is killer btw
