Thanks Thomas - I decided after lunch that I would start into the top frame rails.....and of course me being me I just had to do something completely different for this project.....
Here I am modelling the latest in designer coveralls....
mazfz750 013.jpg (122.08 KiB) Viewed 9586 times
Here are the top rails after bending and the hand made template to check I calculated the bends right....
mazfz750 025.jpg (127.45 KiB) Viewed 9586 times
And here they are mocked up in place......
mazfz750 028.jpg (227.13 KiB) Viewed 9586 times
mazfz750 029.jpg (138.83 KiB) Viewed 9586 times
Tomorrow I'll check all the alignments and tack weld in place.....
SELF INTRODUCTION: Hi Dan, thanks for your time and energy spent on this new board. I hope you will give me a waiver on the email account, I have used gmail so long I don't have a clue what my service provider account is. I just returned home from a 2 week trip in New Mexico, have a few good pix, can't wait to share my off-highway traveling. Got to put 1400 miles on the scoot.
SELF INTRODUCTION: Mark Nienke, I have been a machinest and fabricator for over 30 years. Currently a home shop machinest and future bike builder (some day). Funnest project was my Maadi-Griffin 50 BMG which I built a few years ago. I have owned bikes on and off for the last 40 years. Built and sold two basket case sportsters. I currently own a 2008 Harley V-Rod.
railroad bob wrote:Dual backbones, unusual and interesting...
Nice sweep to the bends. Was that hard to do?
Thanks Bob, the hardest part was working out the original design and then "mapping" the bends - it took a bit of time to work out the start points for each of the bends and to correctly calculate the radius of each one etc, but then I hand bent a piece of conduit to use as a checking template and having written it all down (I like to have a recipe) it took only a few minutes to mark out and bend the tubes. I have to say how impressed I have been with my Gottrikes monster bender, its very easy to use and makes doing repeat bends much easier than my old one....and yes I did get both rail the same!!!!!!
msn1977 wrote:Very nice Maz.
Thanks dude, I did say right at the start this was going to be a very "different" build and I'm sticking to it
More soon guys
yona wrote:Is that little connector what you are going to use, or will you fit a piece, so that they don't have those big gaps on top and bottom /
No its just an off-cut that was the right size to use for mocking up - I've already replaced it with a properly shaped piece.....I tend to use whatever is around for mocking up and then fabricate the proper pieces to fit exactly....I've also reshaped the lower rails at the front (tightened up the top bends) to get them to sit just how I want them..... Next will be the split-plates for allowing the lower rails to detach for motor removal........
Next big jobs will be the gas tank and induction system, plus modify a rear fender ..... ....oh yeah, and I need to make a new set of front forks
SELF INTRODUCTION: I'm a 54yo, fat, balding, bearded motorhead living in the hills of Eastern Ky. 35 year and counting firefighter, retired from 31 years as a crane operator, car nut from birth. I hope my free-mail account doesn't keep me from becoming a member of this message board. Current toys: 1966 Ford Fairlane 500, 1967 Sunbeam Tiger clone project, VW trike project, 18' Thundercraft boat.
