Maz's FZ750 Project
Re: Maz's FZ750 Project
I like the second girder.It has that rough raw look I like.But I would run either.
Yeah, the first one is ultra clean but the second one has a very old look about it....I will probably have a go at this style sometime soon but not on this project...... :snooty: this one is far too "Domme-Punk" and I've already done the design work...... :shifty:
concrete guy
Post by concrete guy »
You're a busy girl Maz! Looks good. Have you ever thought of ditching the tube on the lower cross member on the girder? I quit useing rectangle tube and went to 1/2" plate. Sure seems like it makes life easier.
I never noticed before, but it's interesting that the rear connection for the lower links is substantially narrower than for the top links.
Apparently the lower tree is narrower, in order for the lower links to clear the rear leg of the girder.
The top girder shown above is much better looking, but I have wonder if the lower girder by Tony Foales isn't considerably stronger, since it has the cross-bracing.
concrete guy wrote:You're a busy girl Maz! Looks good. Have you ever thought of ditching the tube on the lower cross member on the girder? I quit useing rectangle tube and went to 1/2" plate. Sure seems like it makes life easier.
now why didn't I think of that? :doh: that would work extremely well with my diamond design........ :think:
thanks dude :bow-blue:
Use a 1/4" (6-7 mm) plate cut to what shape you want that cross piece to be and weld it in like I suggested for gusseting "diamond" so that at the postion it is welded in at the tubing is now 2 right triangles sharing a hypotenuse ( super stiff) and far stronger than any other method of attaching the support for the lower linkage !!
i have a lot of 1/2 x 2and 1/2 bar lying arround and was going to see if i could use it for mine is it better to weld it to the outside or inside of the tube
concrete guy
curt wrote:i have a lot of 1/2 x 2and 1/2 bar lying arround and was going to see if i could use it for mine is it better to weld it to the outside or inside of the tube
I center my 1/2" CR on the tube but of have seen them on the inside and the outside. My pic above is my fixture for holding the lower crossmember support. If you use rectangular tubing, I seem to spend a considerable amount of time fitting this piece along with the legs and keeping all axis's true. I just found out it jigs up much easier this way and I am more accurrate.
Scott
Well I spent a very cold evening out in the workshop fabricating the split tubes for the front of the frame...now I'm back indoors drinking JD and hand painting silly designs onto my boring plain black welding hood..... :hand: a girl's gotta do what a girl's gotta do....... :shifty: :banana-dance: :obscene-drinkingcheers:
Well that's the welding hood painted (not quite finished but it will do....) so now I can get back to some serious fabricating..... :banana-dance:
ampster
SELF INTRODUCTION: got interested in solid modeling and motorcycle designs at the same time - although I haven't built anything yet I do plan on building a custom mc pull behind trailer and will be looking for advise. My Thanks goes out to all the people who have devoted their time into keeping this type of web forum going.
Post by ampster »
Maz wrote:Well that's the welding hood painted (not quite finished but it will do....)
OK, I'll bite...what? No pics?
I put a couple of pics in the General Welding section dude :banana-dance:
So I've been busy making a few small parts from billet aluminium (I'll post some pics in the machine shop section...) and I also mocked up the split front down tubes and radiator....
mazfz750 034.jpg (166.69 KiB) Viewed 7976 times
mazfz750 035.jpg (195.04 KiB) Viewed 7976 times
mazfz750 036.jpg (161.68 KiB) Viewed 7976 times
I still have quite a lot of fabricating to do but I'm pleased with progress so far :snooty: this is going to be a seriously radical punk style bike but she sure ain't gonna be pretty :naughty: :hand: :doh:
Do you have plans to make some sort of cowl for the radiator?
Jeff L wrote:Do you have plans to make some sort of cowl for the radiator?
I'm planning some sort of cowl for the rad but I'm not trying to "hide the ugly bits" as this is a Domme-Punk bike and is not intended to look cute or pretty......
