frankenstein rear end knock-off
Re: frankenstein rear end knock-off
Thanks!!
Did I repair and thread the right section??
If you got me if at all posible the actuall diemension from the part as the one diemensioned in the screen shot I could just connect the reccess in the print???
I do plan to share this with everyone!!!
hose_dragger
SELF INTRODUCTION: Former member of CBH....learning the ways to chop. Had a few bikes before....a few now...and lots more to come. Currently on a trike build, and a bike build. Thanks for having me back on board Dan. Hopefully I will do you guys proud!
Post by hose_dragger »
Thread looks good!
I will see if the dimension is online somewhere, otherwise I really do not want to take this apart again.
Somehow we will figure this out!
I understand!! HA HA!!
Did not relize you had it together either!!
You are definally not messing around building this!!!!
They cost as much as a college education if you want to buy one!!!
I got some more of the prints done on this today see anything wrong???
hose_dragger
Drawing looks amazing. That should help a few guys out there.
here is a pic of it perhaps 95% completed. Just the frame to rear end brackets to make and caliper mount.
26 assembly.jpg (72.23 KiB) Viewed 16183 times
That thing looks amazing!!!!!
I have tried to find diemension for the carrier have you had any luck??
I really do not want to post/release the drawing and have several mad bikers looking for me because that diemension is off and they ruined $$$$$$ in aluminum billet!!!
hose_dragger
Probably best to leave that dimension off till we figure out a way to get it...nothing worse than pissed off bikers hahaha.
Little change of plans and decided to go with this caliper. Will end up being cleaner looking.
Jireh cycles 90-814 Ultima chrome 4 piston caliper
28 Jireh cycles 90-814.JPG (22.97 KiB) Viewed 16174 times
27 brakes Ultima 4 piston.JPG (21.06 KiB) Viewed 16174 times
Man this thing is amazing!!!
I have chewed my finger nails off waiting for you to post more of this eye candy!!!!
What did the caliper cost???
Why would the other not work??
By looking at your housing/carrier housing the right side in print steps down after the bolt length??
Is that true or am Iseeing it wrong?
You get those diemensions if the case and I will add them!!
hose_dragger
Caliper cost 115.00 new with pads...the other I was going to use would of been 35.00 plus 27.00 for pads and been flat black. So I went with this one...other would just need a different mount made up.
Good eye on the step down...I didn't even catch it. Its merely cosmetic though, the important part is for the carrier to fit. I didn't even remember doing that but its only for the eye appeal.
hose_dragger
Got the cut files for the steel bracket back from a fellow member here. Thanks Wendell
Hopefully they will be cut this week. Also got the caliper in and will be making up the mounting bracket this coming week.
P-13-001-01.pdf
(215.16 KiB) Downloaded 743 times
Here is what I have so far for the carrier drawing if you would like to share with your friend as he does good work and is sure to improve on it!!
Maybe we can get the drawing finalized and looking professional???
https://www.dropbox.com/s/hz42faspnt3an ... arrier.dwg
If you could and he does improve it can I get the dwg Cad file link to it!! PLEASE!!!
I remember as a small child riding with my father as he was driving an old mid '20s "T" home after buying it !
It had an external band brake on the axle pinion that worked just fine ... Until one rear wheel lost traction while braking hard on a wet red clay and gravel road and began spinning BACKWARDS at the same rpm as the other wheel was turning resulting in NO BRAKING AT ALL untill that wheel found traction again !
I heard a few new cuss words that day and I have to say my father was very profane as a rule ! It was a a long time before I even knew what those new words meant (other than a sore bottom if my mom or granma if heard me using them )
hose_dragger
few more things on the go....
Thanks for the great details.
Do you bolt it on right here , or further forward?
Rigid Frame
Rigid Frame
hose_dragger
Hiya Hans,
Nope not a bolt on...this would require either modifications to an existing frame or in my case I will build a frame to work with this. That part will probably be a 2014 thing though
