I cann't take credit for this. I found these mods on Caswell's site.If you haven't checked it out yet,you should...lots of info on all kinds of metal finishing.Anyway...here is my gun
- DCFC0012.JPG (16.15 KiB) Viewed 5635 times
...1st... was to remove the difuser, the guy who posted this cut the treads off, but I left them on just unscrewed the difuser
- DCFC0021.JPG (13.47 KiB) Viewed 5635 times
...2nd...I took out the valve from the bottom of the gun, & snipped the end off.This allows max powder through the gun
- DCFC0015.JPG (11.8 KiB) Viewed 5635 times
...3rd...was to pull out the charging peice from the barrel & taper the edges.I didn't taper mine as much,seems fine just taking the flat edge off
- DCFC0020.JPG (13.6 KiB) Viewed 5635 times
...4th...The hole in the fluidizer allows air into the cup, & stirs up the powder so the siphon can pick it up.This hole is facing out right at the cup & isn't able to move much powder.A hole was drilled 180 from that hole.I might also plug the factory hole & add another above the one I drilled.
- DCFC0017.JPG (12.4 KiB) Viewed 5635 times
- DCFC0018.JPG (12.24 KiB) Viewed 5635 times
...lastly...the trigger was sticking even after cleaning out the gun,so a little shot of wd40 on the o-ring in the trigger valve & it moving freely.The difference in how the gun sprays after doing these mods is like night & day.
