Harman
Re: Harman
man i really just forgot. have a lot of family stuff going on. with the daughters activities. Sorry guys. I will get them around as i put a stickit on the bike just a minute ago.
Re: Harman
the OG harman springs were 14.5" long, .118" dia wire with 41 full coils and a ground flat coil on each end to make the full 42. They were topped of with a nylon bushing at the top and a metal weld in retainer at the bottom. they had 6* of rake built into the whole front end.
Re: Harman
Thanks for sharing this info, I'll never build one but it's very interesting anyway.krymis wrote:they had 6* of rake built into the whole front end.
Learn something new everyday, didn't know forks could have rake built in. All I ever knew about was in the neck or trees.
How would someone be able to tell? If you know what to look for, can you tell just by looking, or do you measure the angle compared with the fork stem,
or some other way?
Re: Harman
the angle compared to the fork stem but also the webbing hole on the lower tree mount. You can see on the sporty, big twin, and jap bikes they are different. On top of that the new ones have a cam that makes that angle adjustable from 0*, 3*, AND 6*.
Re: Harman
Thanks...
- BIGJIM
- SELF INTRODUCTION: I am not a bum. I'm a jerk. I once had wealth, power, and the love of a beautiful woman. Now I only have two things: my friends and... uh... my thermos. Huh? My story? Okay. It was never easy for me. I was born a poor black child. I remember the days, sittin' on the porch with my family, singin' and dancin' down in Mississippi.
This
is a fascinating thread. If your looking for custom springs, the companies listed are good ones. There are few who aren't. I would look for someone small, local and hungry.
Krymis, what is the OD of the spring and ID of the tube?
- SELF INTRODUCTION: Just an Iowa country boy that has been pouring concrete for over 30 years. I have been around for awhile. I have watched 3 forums come and go. I built my first chop with the help of the great guys on this forum. I plan on building a few more. $$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$ I don't have the 200 word in me this morning! 8)
Re: Harman
krymis wrote:the OG harman springs were 14.5" long, .118" dia wire with 41 full coils and a ground flat coil on each end to make the full 42. They were topped of with a nylon bushing at the top and a metal weld in retainer at the bottom. they had 6* of rake built into the whole front end.
Thank You!
Re: Harman
Thankyou for that Chris, some food for thought....Found the site below full of contacts for spring help...
http://home.earthlink.net/~bazillion/resources.html
- SELF INTRODUCTION: Former member of CBH....learning the ways to chop. Had a few bikes before....a few now...and lots more to come. Currently on a trike build, and a bike build. Thanks for having me back on board Dan. Hopefully I will do you guys proud!
Re: Harman
I had these wound for a spirder build I did a while ago....
9" long with finished ends
.135 wire
.375 ID to slip fit a 3/8" rod
OD is .650 this was so I could fit a 1" DOM tube with .120 wall
If I remember right the front end had a spring weight of 125 lbs (but mind is getting older and I may not be accurate on that)
.135 wire
- 100_0001.jpg (120.72 KiB) Viewed 4725 times
Re: Harman
Love to see one of these put together....Great info
Eurobods....http://www.industrial-enclosures.com/ht ... lator.html
Re: Harman
Did it go on one of your bikes?hose_dragger wrote:I had these wound for a spirder build I did a while ago....
