Front engined VW
Re: Front engined VW
just went thru your build at the link...
I am floored by what you are doing. Not sure even HOW you know how to mix and match all those parts, or
even make it all work together.
Serious skills there.
- DeathBySnuSnu
- SELF INTRODUCTION: A backwoods redneck from way down south.
I like the smaller motorcycle sized trikes.
This thing is packed in there to make it this small.
Last edited by DeathBySnuSnu on Fri Sep 29, 2017 10:00 pm, edited 1 time in total.
- DeathBySnuSnu
railroad bob wrote:just went thru your build at the link...
And that is basically just the engine.
The trans and everything else is a mix match hodge podge of stuff that ain't supposed to fit together.
When the original build happened was before smart phones and always having a camera in your pocket. I have just a few pics of the original build towards the end, I got me one of those new fangled digital cameras that had just came out.
- DeathBySnuSnu
It is finally coming together.
- 20160712_170050_zpspbe21vnf.jpg (158.65 KiB) Viewed 5618 times
Last edited by DeathBySnuSnu on Fri Sep 29, 2017 10:08 pm, edited 1 time in total.
- DeathBySnuSnu
A couple current pics.
- DeathBySnuSnu
- DeathBySnuSnu
- DeathBySnuSnu
wow, that thing is wickedly cool. even more so to me since my daily driver is a '69 VW Type 3 Squareback.
looks like the intake manifolds are custom made, and i can't quite tell what the carbs are. Dellorto?
- SELF INTRODUCTION: I first found the chopperbuilders handbook back in 2004. Thanks to the board, and all its members, I was able to build My bike, and have ridden it 25,000 miles. I learned a lot, made some friends, and had a great time building it
You have a nice project going on there. One question though, is it hard to get on and off of it with all of the carbs and exhaust located where they are?
I first found the chopperbuilders handbook back in 2004. Thanks to the board, and all its members, I was able to build My bike, and have ridden it 71,000 miles. I learned a lot, made some friends, and had a great time building it
- DeathBySnuSnu
Ahaaaa....another vw guy huh?
I no longer have a vw car. Well....not entirely true....I do have a 61 Karmen sedan convertible that I want to make a volks rod out of. But it is just a pile right now.
Yes the intakes are fabbed units and no that is not carbs or Dells.
That is 44mm mikuni throttle bodies and Mitsubishi injectors.
This is a 2387 fuel injected distributor less stroker motor.
- DeathBySnuSnu
It is more difficult than a standard motorcycle to get onto.Jim Sawyer wrote: ↑Sat Sep 30, 2017 9:26 am You have a nice project going on there. One question though, is it hard to get on and off of it with all of the carbs and exhaust located where they are?
Luckily it is low. When you swing your leg over the seat you just have to continue on over the air cleaner also.
Which in itself is no big deal but by the time you leg is that far out you are past balance point and just plop down on the seat.
LOL, if i had just looked a bit closer i should have at least seen that they were injectors. been a long day.
2387 cc in that light frame is gonna be one wild ride for sure! great googly moogly.
i likey.
i likey.
- DeathBySnuSnu
It spent a large number of years as a 2110 big head big cam with 44idf clones.
It was quite twitchy with 3.88 ring and pinion.
It wound up putting in a 3.44 ring and pinion, 1.26 third and a .82 fourth. That helped a lot. Before it physically took longer to shift it than it took to pull the gear. Was common to hit valve float before you could stick the next gear. The bigger gears put a little time between shifts.
- DeathBySnuSnu
As this is a motorcycle forum, most of my posting is of the motorcycle nature.
I have not put much of the engine trans vw stuff up here.
If y'all want some pics of the less motorcycle type parts or info on the mechanical I can post that up.
