1979 Honda cb750
1979 Honda cb750
Hey guys and gals, I am trying to remove my trees from bike. There is a nut on top to undo, first time removing trees. I need them off upper and lower for my springer to mount up, any help greatly appreciated. I can take picture if needed.
Re: 1979 Honda cb750
Here is a pic of trees I need removed for springer front end.
- 100_1779_zps122df859 Trees removal.jpg (229.91 KiB) Viewed 6373 times
Just unscrew the Nut & the top Tree should pull off.Might be another Nut, undo that & the bottom Tree will fall out of the Neck.You'll have a Washer or 2,Dust Caps & Bearings top & bottom,(mine are Ball Bearings so be carefull when taking it apart).the Races will be press fit in the neck.Go through the Neck with a long Punch & tap the bottom of the Race if you need to remove them.
Thanks Jeff, got it all apart now. Doing mockup of springer front end.
Trying to remove lower tree from steering shaft, no nut to take off. Looks to be press fitted inside tree, want to use steering shaft for springer front end.
- 100_1788_zpsd959b876 steering stem.jpg (144.78 KiB) Viewed 6353 times
This is how I have seen it done cut out then welded it to the tree lower tree. Or turn it like him
There are a few on E-Bay for cheap.You could always sell your complete Frontend for a little Parts Money.
Thanks guys, already cut out the lower tree from stem.
- 100_1789_zps4aff79ee springer front end steering stem fab.jpg (188.03 KiB) Viewed 6335 times
