Bottom tree and spring perch plate connection to legs
DKillam
SELF INTRODUCTION: Hey dan - it's me again! PLEASE let me join!! My password is "peanut brittle" and I like to share. :) Thanks for taking on this huge undertaking - I'll try not to disappoint - after all, I'm not through with my build stuff!
Post by DKillam »
I've been giving some thought to brazing the bottom tree and spring perch plate to the rear legs instead of welding them. In doing so, the tree and perch plate would be beveled at a 45 degree angle (1/8" bevel) on the top and bottom sides of the tree and perch and brazed and finished with a small fillet braze.
The flux would be Peterson #1 blue and the rod would be 1/8" Hobart bare brazing rod.
Gary mentions brazing in the Final Welding section of The Rude and Crude Old School Springer Build:
"Pay special attention to the welds where the lower tree attaches to the rear fork tubes and use minimal heat and minimal penetration at this juncture. In fact this connection only really needs to be welded on the upper side of the tree and not on the bottom. For several years now I've been contemplating brazing this connection or using a Nickel solder, as this is where Springers fail on a routine basis."
I Googled Nickel solder and found a variety of percentages of silver - anywhere from 30% to 75%.
Questions:
Would the brazing method described in the first paragraph (using bare brazing rod) be strong enough for this purpose?
What percentage of silver solder wire would be best, if brazing rod isn't strong enough?
Thanks for any insight.
Fossil
SELF INTRODUCTION: Just an old Dude exploring the world while I still have time. Used to be a member here but forgot my login information so trying to re-register. Working on the placer deposits in Nevada so no roads here to ride anything on unless it;s a dirt bike and even that can be pretty hairy. Nice to see that the place is still active. The old CBH is due to go offline in November. Have to computer anymore and cell signals out here are few and far between so it's hard to maintain any type of regular contact with anybody but glad to see a lot of familiar names.
Re: Bottom tree and spring perch plate connection to legs
Post by Fossil »
On the old days some of the guys who were building springers used conventional welding at the connection between the top of the bottom tree but used gunsmith solder at the bottom connection so there was no appreciable HAZ at that location. The perch should be welded top and bottom as it's under significant loading.
Fossil
Post by Fossil »
Back then we were all running much thinner tube legs than we do today so bottom fractures in the HAZ were common. With todays thicker material and Tig welding the heat damage is less.
DKillam
Post by DKillam »
I’m using 3/16 wall on the front legs and 1/4 wall on the rear legs. Any problem using MIG for these welds?
Fossil
Post by Fossil »
No problem so long as there is no weld under cutting in the tubing which is a problem seen on springers, girders and leafers.
Fossil
Post by Fossil »
Under cutting on tubing welds is one of the most common reasons for failure primarily because it reduces the tube wall thickness right in the middle of the HAZ which is the worse possible place.
Hopefully this little gif will illustrate the situation
DKillam
Post by DKillam »
Thanks - I appreciate the info. Next step is to make a simple welding jig to keep everything aligned, then weld ‘er up.
Don
