Sorry Friend!
Got the filters done.
Welded 8 pieces together and put on rotary table. Milled the centers out and drilled for 6 bolt holes.
Milled the outer size.
Cleaned up with a air grinder.
Took a new Fram filter I have had laying around here for years.
Cut it open with grinder and razor wheel for materials.
Made the screens from it.
Welded nuts to the back of the inside rings.
Welded these rings inside the tubes.
Cut the filter material from Fram filter to shape.
It is held between two screens.
Installed on the bike.
